Advice on picking a transmission
- Orlando, FL
- 1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
So we are working on narrowing down our drive train, and we have started to consider getting a AmC 360 for $AMC 150 and little by little working on it to possibly drop it in in the future.
After reading a bunch of threads and material on the net with articles like Busa http://www.jeep-cj.com/forums/f105/manual-cj-transmissions-12112/#post97088 and Jeeptech.com's Jeep Transmission Page
Airstrikes http://www.jeep-cj.com/forums/f2/t18a-right-18484/
I think I know a little more about transmissions, I'm just not sure about how that translates to what we have and our current application.
First we currently have a 1985 AMC 258 i6 / 4.2l /T-5 /Dana 300 . The PO told me the T-5 was just rebuilt and it appears to be in a new gear box. We will be running 33's, very little off road, and mostly a daily driver. The vehicle only came with one drive shaft that is 32 and 3/4 inches long (from bottom to the bottom of the U), so I will need to at least get one drive shaft any ways. We are currently doing off frame restoration so everything should be pretty accessible.
Thanks to PetesCJ I got a nice Transmission crossmember which we refurbished. It also has Dana 44 in the rear with disc brakes all around.
So here are our choices.
86 CJ7 T-176 with a Dana 300 for $500... I know a guy that is looking for a Dana 300 that I might be able to part with him to $AMC 150 , so the tran costs me $350, $AMC 150 for the rebuild kit, $250 for the labor, I bolt it up to my Dana 300 , use the same bell housing (I think I have to change to pattern) and eventually I can use the 360 with it. The seller also states he has a matching gm bell housing, I'm not sure if he is referring to those that want to use it on a gm application.
79 cj T-18 with a Dana 20 .... I am told this used to be in a cj, with the wide ratio. I am told it is rebuilt 6 yrs ago, with a new top cover, all shifters but no bell housing. the seller drove it a couple of months then removed it in favor a Dana 300 , let it sit in his garage. He would like around $600.
So I would sell my 300 to my buddy for $AMC 150 , sell my reman T-5 for ? and use this set up.
a. what do I use for bell housing?
b. I loose the Dana 300
c. Maybe not a great daily driver
or
Do I get something different from either like get a ax15, sm420, sm465, nv 3550, from http://www.georgiaprecisiongear.com/Transmission_Pricing.html for about $700-900 reman.
a. what bell housing
b. do I now have to get from Novak an adapted spline shaft ($190) and clocking ring ($170)?
c. the Ax15 is desired to have the external clutch cylinder found in 94-99... is this in the actual Transmission or in the bell housing?
Any advice or thoughts would be greatly appreciated... below are pictures of the T-18 /Dana 20
or
