Alternative proportioning valve
bwmetcalf
Wimberley
'79 cj7, amc 360
I posted last weak about my third proportioning valve of this style leaking:
https://www.morris4x4center.com/disc-drum-proportioning-valve-brass-mbm-pv2.html
I'm tired of replacing it and reluctant to spend the money on one of the same style from a different distributor.
Is there an alternative that can be used with a corvette style master cylinder? Can something like this https://www.jegs.com/i/JEGS/555/630...riteo&utm_medium=cpc&utm_campaign=retargeting be installed for the rear drum brakes and run the front disc brakes directly from the master cylinder.
Just looking to solve this issue once and for all.
Thanks.
Ditto on Summit
$35.00
  17.5%
