AMC 20 axle seals
AMC 20 axle seals
lgbent
Morven, NC
72 CJ5, 73 CJ5, 78 CJ7, 79 CJ7, 85 CJ7
Hi guys & gals, I'm putting 1 piece axles in my 85 CJ & I wanted to know should I put new inner seals in & use grease on the bearings, or leave the seals out and let the rearend oil grease them? Thanks, Grant
That makes install easy as pie, wish there was a PDF like that when I installed mine oh so many years ago...
With out the inner seals it will leak fluid.
Thanks for the info. Keep on jeeping
Remember even if you don't support the war,Support Our Troops
Grant (USMC)
