AMC 20 Disc Brakes
Ultrunner
I am few bolts away from pulling my front and rear axles out from the frame. I have an AMC20 rear and am installing a Moser one-piece shaft, swapping out the ring and pinion and replacing all the bearings and seals.
I thought while I'm at it, upgrading to disc brakes. I have seen the SSBC kits and have read okay reviews, nothing earth shattering either way, so I decided to go that route until...
I just found out that SSBC closed its doors and the kits are no longer available. Are there any other routes to converting to disc brakes on the rear end or should I just stick with a good drum rebuild?
