    Thank you for your support!
AMC 20 Disc Brakes
AMC 20 Disc Brakes
There's a company near St. Louis where I'm from that rebuilds Jeepsters (Just Jeepsters). I had some axle questions for them and asked where I could get a read brake kit for my Dana 44 that wasn't SSBC. They use TSM exclusively for their kits and rebuilds, so they told me to give them a shout.
They're a small business and their customer service is top notch. Just need to stock up on their rotors if they ever go out of business! The calipers are from an 80 El Dorado and a few other vehicles, so everything else is easy to find.
Thanks again, I just reached out to them about purchasing a kit. I’ll have to check on the parking brake since I’m doing a total rebuild and completely ripped my parking brake cables apart.
If they're unsalvageable, then you can order another stock set...or rig something up yourself. The kit comes with some extension adapters in case the cables are a bit too long. I didn't need it on the driver's side, but I needed it on the passenger side.
Sent via Google translate using braille through Tapatalk
