Anyone else having trouble with thier Bestop?
I spread mine out in the sun for a couple of hours before I put it up. I try to do it on a warm day on warm asphalt.
I have the Bestop Supertop. The top does go up better in hot weather but I'm most concerned about it going up quickly when it's cold, and raining and hailing.
It is impossible to pivot the main support bar up when the sides are already zipped. But I can extend the diagonal rear bar after zipping the sides.
There are 4 notches that I could latch that diagonal bar into. With a lot of force I can get the bar into the first notch. The others are useless.
I am working on a fix today.
would it have done what you wanted to do if you drilled another "notch" hole down an inch or so??
you would not actually shorten the bow just take some of the pressure off it.
I'm in IT. I have hard drives coming out my rear.Do you have a source for dead hard drives??![]()
How did you attach the magnets?
A fellow club member showed this to me ions ago. Making a little snap attachment (Third pic),and install it on the top bar. This will make the rear window be able to open without having to roll it up and not leave the permanant marks from the supplied straps. Plus scratch the window from that is dirt already on it.
