Build Thread Aussie CJ7 - 78
JAG811
Tools down and I have to go into work tomorrow so that might be the end of it for this weekend.
So the diff is out now and it's round two in the "clean a diff" stakes.
Can't say I'm as enthusiastic, second time round ...
Once the diff was out I had to cut through the bushes (of the last spring) with the grinder and a cutting disk - To cut into the spring eye bolt that was firmly rusted to the steel sleeve
You'll noticed I drilled a small hole in the frame plate for the diff bump stop.
I'm hoping this will serve as a great way to get the sway bar out of the way when disconnected on the trail ... time will see if it works or not.
Lastly just out of sheer amazement I attached a photo of the cir-clips holding the sway bar bolts in ... I was NOT expecting to see them ... I've only really seen them used to hold disks onto wheels and they annoy the hell out of you if you need the disk off !!
