Build Thread Aussie CJ7 - 78
JAG811
Waiting for paint to dry so I pulled down the calipers.
Heaps easier just to put a block in the caliper and blow out the piston with compressed air, but for those with just rocks and sticks .. I had to gently tap out the piston.
Should also say I have a 78 which means 6 bolt 1 1/8 set up.
You can see the piston almost right out and then once she came out ... Not real flash at all ....
Although it looked like the piston was fine with only gunk built up, no pitting or damage.
 till you took it all apart and "fixed" it.
