bare with me ha
LongHorn
Always Off-Roading Jeeper
- Media
- 39
- Washington Co.,Texas
- 83'CJ-8 Scrambler Slightly Modified;),48'CJ2A, 54'CJ3B 67'Jeep M-725, 88'YJeep Wrangler Slightly Modified;)
Waggy axles are alot wider than yours. I run full width full size axles but they stick out alot, look at my pic's.Waggy axles are 6lug so you'll need different wheels. The rear axle on your jeep should be center not offset. The non vac um disconnect is a stronger setup.Passenger side drop front axle is correct for your Dana 300 Transfer Case .
