Clutch Bellhousing bolt size for the clutch pivot ball bracket
defibvt
AZ
1974 CJ5, 4.0L stroker from a 91 XJ,T-18 w/ granny gear, Dana 300 w/ Lomax 4:1 gears.
What is the size is the bolt for the pivot ball bdllhouding bracket. Mine is 74 CJ5 .
Sent from my SM-G965U using Tapatalk
I can't type. * bellhousing
If you mean the bolt I circled here, I thought they were 1/4-20. But since I pulled all that and switched to an auto, I no longer have any of this hardware.
That's it! I knew it small and fine thread. Thank you so much.
Better get two 3/8-16 also. That's my recollection on the size but I may have drilled them out for strength. :wtf:
Thanks for the heads up. I don't think the thread pitch is 16 butbi will keep a look out when go through my stash.
So my bolts ended being 5/16x18. My bellhousing isn't stock so that maybe why.
That's and odd ball size but glad you have it worked out. :punk:
