Misc. Best garage floor cleaners?
Petescj
Member
Lifetime Supporter
Featured
PA
What have you used mostly to get up oil spots on your garage floor? I pulled everything out of my garage and pressure washed the floor but spots didn't come out as well as I wanted.
Thanks in advance ☺️
I've had great results with POR 15
EZ way:
try purple power or simple green and let it soak. Sometimes I add a little wd40 in with the simple green in a spray bottle, good degreaser.
Stubborn stains:
Dawn dish soap, if you mix a powder dishwasher soap or baking soda you can make a paste you can scrub with a brush/broom. Scrub it in real good and let it sit under plastic so it doesn't dry, then hose it off.
Also use hot water, real hot, it'll help break things up.
How do I? Oil seal
$100.00
  50.0%
