Misc. Best Top Bikini top
VJP
Connecticut
80 CJ5
Pretty strange. What company is making it ? Do you have a picture of it spread out completely on the ground so that we can see what you have ?
Seeing is believing. I wonder if they got a batch in from chinee and haven’t looked at them and hosed up.
I have had about 4 in over 40 years, A couple different models and they all had the plastic lip sewn in, which is used in the aluminum channel screwed into the top of the windshield frame. Also on each side is a snap to hold it in place.
Yeah that looks like an aftermarket channel and different from my OEM that mine came with off the truck. Mine is straight across and not bent down on the ends
I’ve got the same Bestop bikini top, strapless, but in black. Doesn’t have the plastic “blade” like older tops. Takes a different channel which has a groove that corresponds with the thick seam to be inserted instead of thin plastic blade. No snaps either, but they wouldn’t hurt if you wanted em.
Haven’t had any problems and I’ve trailered it at 75mph with bikini on.
It will, but very little. When you install those snaps, it's like a rivet in that you have a small portion that is on the underside. So when installed on the channel, you'll a small flat portion inside the groove of the channel. This will take up perhaps 1mm of space in that groove where you're inserting the rigid insert of the Supertop. But shouldn't be an issue.
  5.0%
