Best way for removing undercoat
GoldenEagle36
SW Pennsylvania
1977 cj7 Golden Eagle 304,automatic, Quadra-trac, full restoration just "finished." 4 inch superlift, lift shackles in the front, sitting on some KM2 Mud terrians
1999 tj 4 cylinder ax5 trans 3 inches lift 31s
1956 Dj3a all original except axles and engine, Hurricane 4 cyl. 4x4 conversion, 27,500 original miles 58 Jeep-A-Trench cj5 8000 miles.
I just would like to know what is the best way to remove thick heavy undercoat. I believe Ziebart was huge for undercoat but the guy that had my 77 CJ7 (or what was a 77) went :censored: crazy with this stuff its all over the place and i would like to use the hood but the weight is doubled. so what do you think is the best way to remove it. Some things i have done;
Gasoline-today its not worth a :dung: today so it didnt do anything
Diesel- same as gas
Goof off- it did work but it really wasnt that good
WD 40 & PB Blaster- Nada
Please help me!!! Thanks!!
Torch and scraper, smells bad but works, also kleenstrip or aircraft stripper works. Use in ventilated area.
I would try a heat gun and a putty knife.:cool:
The aircraft stripper sounds promising, try a little brake fluid, that removes paint faster than anything I know of LOL.:D
Brake fluid will remove paint, might be worth a try. If the tub is off the frame take in and have it shot blasted, strip it down to the metal. The shop will know what the best medium is to use.
Thanks guys and i did try brake fluid and it didnt work also but i was wondering if a sand blaster would work......hhhmmmm ill try the thinner and stripper keep the ideas coming!!! and by the way the under coat is on THICK.
I don't think the sand blaster will touch it. did you try a heat gun??
sounds like it may be easier to get another hood lol
Well what i wanted to do was use the axles from under the Golden Eagle because it runs and drives completely perfect but the tub is shot as well as the frame so i just wanted the axles and the front clip (im not going to use the front clip off the Golden Eagle Im using it off the Doner) i just want to keep the other front clip as a spare or build another Jeep. i think a torch is the best approach but keep the ideas coming!!! Thanks
well i found out like two weeks ago that paint thinner and a pressure washer is the best way to go took the undercoat right off my axles and other suspension components
