Body drain hole plugs
BrockGrimes
Jeep-CJ.com Archive Master
Kathleen, GA
ON THE HUNT AGAIN
you plug those? I use them holes to judge how fast we are going down der road. sheesh now I find out I need to use the speedo. Imagine that
Traveling at speed through water and a having a stream of water shoot out the hole and into your crotch you learn to fix those things quick.
water, whats that, I live in CA
I use stainless steel electrical box plugs. I can see these being easier to remove and replace when you want to let the water out. excellent idea.:chug:
They are made of rubber that is resistant to brake fluid so they will last awhile not mention they conform to the hole so no worries about it fitting in a floor that's been lined.
I like this. Good idea.
