Bought a 83 CJ-7, need a detailed pic of a 4.2 engine
83power
Hello, I am looking for a detailed picture(s) of a smooth running CJ7 engine with a carter carb and Nutter bypass.
Just purchased a (very rough) '83 CJ7 with a AMC 258 i6 / 4.2l , Carter Carb, automatic, electric choke, Nutter Bypass.
Thanks for the Time!
- Need to install vacuum lines...correctly
- I have a 3 port CTO valve...I think it should be a 2 port
- I don't see the EGR anywhere, I need a picture of that also? or do I even need it?
- I don't have a stepper motor or needles, just a block off plate
- Both of my idle screws are all the way in, but in or out...no difference! barely idles, idle adjust is at its max turns in
- Smoke and Oil comes out of the air breather hose?
