    Thank you for your support!
Brake Line Size
Brake Line Size
Peanut Butter
Full Time Jeeper
Boerne, Texas
1979 Jeep CJ7 TH400 Automatic 258 I6 Quadratrac Amc 20 rear & Dana 30 front, 32 x 11.5 x 15 tires. Currently a Complete Custom Rebuild in progress.
Also I own a 2001 Jeep Cherokee, White, all stock with 4.0L. automatic, and police package. Best part of that is it came with leather seats! This package also has the NP242 Transfer Case, 8.25 rear end, and trailer towing package.
Looks like I'll be able to get back to my CJ7 rebuild after the 1st of the year. :D I need to replace all of the brake lines. :( The line that runs across the rear axle seems to be smaller than the rest of the lines. What size tubing should I get as I need to replace the entire system. Would stainless steal wrapped brake hose work as well if placed in a protected area. :rolleyes: I'm sure others have bent their own lines, what did you use? Thanks
PS: Power front Disc and Power rear drum is the plan by adding a vacuum booster.
Use a hard line.
Take the old brake line with you to the parts house to be sure the new fittings are correct.
I've made my own brakelines before from the split. I used ¼" tubing which was readily available in a variety of lengths. This was from necessity after splitting a rear line while wheeling.....I carry the flare tool, bender, cutter and extra flare nuts in my Jeep along with some extra ¼" tubing (which is also compatible with my clutch lines)
I have not made the long main brakeline...and I don't think I would try it given all the precision bends and frame placement....I would just purchase that. But to each his own. :D
I use 3/16” Poly-Armour PVF steel tube comes in a 25' roll for about $20 at AA
Are you able to use the existing brake line nuts with this, if you double flare the ends?
I enjoy bending my own line. I find nothing hard about it especially if you save the old lines and use them as a guide. All the fittings worked as they should.
I did the same thing with Adel Clamps, when I plumbed my 9".
