Brake Switch on Proportioning Vavle is wrong plug
gadawg31
Ok, finally got all of the brakes buttoned up and forgot all about the brake switch in the middle of my proportioning vavle. I replace the factory valve with one from Morris 4x4 and it is an exact match, except the brake switch has a different plug. I tried swapping out the old plug, but the hole size is different. Has anyone converted this from two wires to one wire? The original switch has two wires and the new valve only has one. I found the wires on the diagram, but this is where my electrical expertise ends. Anyone have ideas or solutions? Thanks.
JD
JD
