brake ?
brake ?
dalefan88
Crazy Sr. Respected Jeeper
ada,oh
79 cj5 258, t150, dana 20 transfer case, dana 30 front, 20 rear,warn hubs,2.5" procomp lift,teamrush,msd box,mc2100 carb,hedman header,clifford intake,optima battery, ford shock towers.
i really dont like the calipers on my jeep. is there and way to change them to a say like gm caliper with 2 slide pins? this would be on a stock Dana 30 on my 79 CJ5 .
I have a Dana 30 that was set up for jeep disc
I got the gm calipers and brackets to mount them from Herm The Overdrive Guy, we have a link for him in the Links section under parts I believe. Anyway I had to grind the mounting tabs off the stock knuckles and bolt the brackets on. He sells them as part of a kit, but if you called I bet he would sell the calipers and brackets only. It is a sweet setup when finished as those are great calipers.
so i just couldnt go to work and buy brackets and calipers from another car or truck and put them on. just wondering cause i dont like cutting on things like that.
I have a D30 that was set up for jeep disc
how much was it?
I paid 600 for the entire kit, but that includes new disc and hubs and bearings, All you would need is the calipers and the brackets, I am sure if you can source the calipers yourself he will sell the brackets.
i wonder if the brackets are custom or if the are oe on a car or truck?
