    Thank you for your support!
Brand Question
Brand Question
Scout1067
Old Time Jeeper
Germany
1981 CJ7, 258, T176, D300, D30 front diff, AMC 20 rear diff, Weber Carburetor, BDS 2.5" lift
I have seen several people on here talk about how Omix/ADA are trash for parts although so far I have had no problem with the few parts from them I have ordered. That begs the question to me then about what the consensus is on Rugged Ridge parts since they are a subsidiary of Omix.
Specifically, I am looking at changing out my leaf springs to get less lift and a softer ride. I currently have 4 inches of lift and almost no play in the suspension on bumps which makes for a pretty jarring ride. I just had my second cervical spine surgery and am pretty sure that banging around on bumps can't be good for my neck. Since my CJ is my daily driver I want good parts that give me good ride and will last a while.
old man emu I have heard nothing but good things about their springs
Omix Ada is a :dung: shoot some of their stuff is fine some of it is not, I have their heater cables and the labels feel off and the knobs started. Turning to :dung: after that
Old Man Emu ! Only 2 1/2" of lift and they offer soft to heavy spring rates.
Crown is another brand to watch out for, both sell parts made in China. I have bought from both an it's definitely a :dung: shoot on quality. I find using Rockauto is a good choice if you want a selection of manufacturers to choose from on most parts, sometimes however Crown and/or Omix are the only choice.
For lifts there is a good selection of manufacturers to choose from.
