Breaking in new LOW gears
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
In the Trail report forum one of the drivers installed a new set of low gears in his Transmission . I suggested a break n period and Mr. Bass came back with his break in experience with heat. Since I have a transmission/Transfer Case ready to install my curiosity created this new thread.
If you have a set of low gears in your transmission how did you do a proper break in of those gears. I understand running for 15-20 minutes and letting things cool. How many times did you do this? Did you run for a while in 4wd high, then drop it into 4wd low for 15 minutes each? How did you do the break in?
I suppose this would do for my transmission as well, it had some rusty gears that were swapped out for good used gears.
I imagine this would be true for all gear driven parts like the differentials.
). Once there, things run considerable cooler.
