Caliper brackets install
Mrpeter63
Woodstock
1983 CJ7, 4.2, T999, D300, AMC20, D30
I have the ford style caliper brackets pre '81 or whatever. Anyways, my question is the location of the retaining bolt for the caliper clips. The only picture i can find is of the right side and shows the hole on the inside bottom. Is this correct? Are both sides suppose to be on the inside bottom? The problem i have is i can mount one side, left or right, with the hole on the inside bottom. But i can't get the other side to match without the dust shield being in the way. Yes, i have two different caliper brackets. Only thing i can think of is i have the dust shields on the wrong side but figured i would ask before i took the hubs back apart. I knew i should of put the brackets on first lol... Thanks!
