Camshaft Recommendations?
Niedhogg
Old Time Jeeper
- Thor, Iowa
- '79 Jeep CJ7 Renegade with 304ci V8, TH400 auto, Quadratrac T-case, Stock 20 and 30 rears with no mods yet, not sure of the gear ratio.. 4" Softride Superlift, w/widetrac shock towers and 35x12.50x15 BFG Mud-Terrains
'76 CJ5, 232 ci, T-150 3-speed, D20 T-case, Corp. 20 rear w/full float axles and lockout hubs and Detroit auto locker, D30 front w/lockout hubs, gear ratio is unknown..
I'm trying to get a little more power out of my AMC 304 , and could use some suggestions..
I have a '79 304 that was a totally stock smog engine when I started. I have removed all the emissions, and have added headers, an Edelbrock Performer intake, and a 470cfm Holley truck avenger, and converted the ignition to HEI... It just seems like it should have better accelaration, it's really sluggish, and it is using copius amounts of gasoline. I know there are other factors, I am unsure of the gearing and I have 35" tires. I am planning to check the float levels on the carb today as I think the rear bowl may be running over, because the last time I had the carb off the back two barrels were really wet at the base gasket. The carb is new from Holley and has the factory settings. Could that be causing my sluggishness?
I was also going to upgrade the cam during the build, but I had a time restriction that I just didn't feel like I could finish the project if I'd tackeled that too, so, what would you guys suggest for a cam size for my motor, I'm not really worried about the gas cosumption, but for all the gas it's using I'd like to at least have the power to show for it..
