Can I swap a T14 with a a T15?
73CJ
Crazy Sr. Respected Jeeper
Detroit Lakes, MN
73 CJ5 4.0 head on a 258, HEI, Holley Projection w/ 4.56, Detroit lockers Narrowed D44 front and full float D44 rear T14 w/ D20 4 wheel discs, 38.5 Boggers
As far as splines, the output splines are different but you say you have a Dana 20 already on the T-15 you want to toss in.
And although the input shaft looks like it may be slightly different on the pilot bushing tip diameter, this should be a fairly easy swal I'd wager.
T-15 is very slightly larger (longer) by by ?/16th's so not much if any drive shaft mods?
Here's where I am reading from on them both.
The Borg-Warner T14 Jeep Transmission - Novak Conversions
The Borg-Warner T15 Jeep Transmission - Novak Conversions
But to your main question, "I" have never done it... Though it looks as if the T-15 was available as a stock option behind the AMC 258 i6 / 4.2l ...
~ JR
