Can you ID me?
Can you ID me?
Receo
Sandy,Oregon
1984 cj7.
Horn, wipers,Head tail brake lights all working. Blinkers good and the oil pressure and volt meter work. Engine fires right up. Everything else having to do with electricity is dead. All the smog systems have been pulled so I kinda suspect that the un identified connectors might have belonged with that system. I figured the connectors were so big that they must go to something important. ;4)
Truly amazing how fast the day goes by when your working on a jeep.
Receo,
:)You sound like you can get things up and running again , just a process of elimination to trace the wires back to the switch or source. I'm sure some other guys will chime in with similar vehicles that have seen those plugs before.
Good Luck!
:D:D:D:D
Receo - Having just wired up the dash in my 75, I think I can help a little. The larger plug in the second photo attaches to the headlight switch. It's the same style connector that was on my Painless harness. I'm pretty sure the smaller plug attaches to the brake light switch. The plug in the first pic maybe for the heater?
Hope that helps some. Good luck - Bill :chug:
Awesome! Thanks for the help. The headlamp is currently running direct wired to an after market rocker switch. I don't have the oem headlight switch but from looking at pics of them I think your correct. I never considered how the original owner wired the breaks because they work fine. I'll add that to the list of things to investigate.
  • Locked
