Carter AFB will not idle down
Turbogus
Old Time Jeeper
- Albany, OR
- '78 CJ 5 Renegade (Black Betty) Motor AMC 360, T150 trans, 20 tc, Dana 30 front and Dana 44 rear w/posi
'96 GMC K1500 Suburban (Big Blue Basterd) fully loaded with over $10k in options
A couple of years back it developed a small leak at the primary throttle shaft. I sent it in for bushing installation and following that I did a bebuild with a Jiffy kit.
I lost the choke pivot pin (nomenclature unknown) that connects the piston to the lever inside the electric choke. I found that a smooth paper clip, cut down to length fit nicely in the tiny bore.
Time has gone by and after doing other work on the motor this AFB is on despite several attempts I can't seem to diengage the fast idle cam, unless I manually disengage it by reaching under the air cleaner and doing so. It may be related to the repair I mentioned above but I'm dubious.
There's no binding in the linkage that I can determine.
this was marketed back in the early '80's as a 'Black Stallion' model from Carter. I used it fresh out of the box on a steel crank 4 bolt main 350 that I was building for another mid '60's Chevelle. Turned out the cam went flat in the lowered '77 Chev short wide truck I was driving, so there it went. When I eventually sold that truck I pulled the motor to sell seperately but my best friend saved that carb for me.
