Carter AFB will not idle down
Turbogus
Old Time Jeeper
Featured
Albany, OR
'78 CJ 5 Renegade (Black Betty) Motor AMC 360, T150 trans, 20 tc, Dana 30 front and Dana 44 rear w/posi
'96 GMC K1500 Suburban (Big Blue Basterd) fully loaded with over $10k in options
Are you getting 12 volts? Coil broken? I’m on Tapatalk and it won’t let me see the pics
Cool, is that an old Carter Marine carb?
No Gert, :D this was marketed back in the early '80's as a 'Black Stallion' model from Carter. I used it fresh out of the box on a steel crank 4 bolt main 350 that I was building for another mid '60's Chevelle. Turned out the cam went flat in the lowered '77 Chev short wide truck I was driving, so there it went. When I eventually sold that truck I pulled the motor to sell seperately but my best friend saved that carb for me.
Oh wow that’s pretty cool, never knew that
I sure did Torx, and while there were springs aplenty, most were too heavy for a throttle return spring. After the new springs arrived I got it somewhat dialed in yesterday at work, the kickdown now works just like its supposed to. Now just got to figure out the delay on the e-choke. :D
I was able to take 'er to work today and dialed in the fast idle so it's working perfectly now and the e-choke delay is just right. :D
Now wait for the next thing to go wrong. BTW, I saw that spring set you pictured in post #7 at my local AZ, these were even chromed.
Yeah, there's always something to attend to...
    Best for votes
    on specific items
