Charcoal vapour canister on '77 CJ7...and its connections
Rdavison39
Oakville Ontario
1977 CJ7. 304 H. 52,000 original miles.
2010 Wrangler 2Dr
Hi there - i have a vapour canister in my CJ7 and i'm not sure how to make all the connections properly. I have one green tube that i traced that go back to rear of the jeep that just hangs there - i suspect this is for venting the gas tank.
Does anyone have a diagram that shows where all the tubes for the vapour canister are suppose to connect to?
And does anyone have a part number for the filter cloth one uses? This one i think is the original :)
Thx
Ron
Wanted to follow up on this question regarding the Charcoal canister and in particular how to hook it up correctly on my 84 CJ7 with an AMC 360 and Holley 4 barrel carb.
I am trying to hook up the lines from the canister to the appropriate ports. I have seen the diagrams for the standard canister hookups but they always refer to the original set up. My questions are:
1. The line that ran from the ported vacuum on the canister to the carburetor, should I "T" that into the timed vacuum port on the Holley carburetor? I currently have the timed vacuum port connected to the D.U.I distributor.
2: Where should I run the line that originally ran to the carburetor bowl vent? I have read that it can be run to the bottom of the air cleaner but wanted to see if that was correct.
Any assistance/guidance that you could provide would be greatly appreciated.
