cheap disconnects
cheap disconnects
rzide
WV
1984 CJ7 304 v8 auto.
I have the pro comp 4" and would like a way to easily disconnect the sway bar. is there a cheap kit out or a way to make my own without fabricating anything?
I'd try running it without the sway bar first, most people with a 4" lift find that they don't need it anymore as the springs are stiff enough that it drives fine without one.
There are several write ups on how to make your own disco's. Id run it first to see if there is a need for the sway bar then make em if needed.
