cheap TBI??
cheap TBI??
IOPort51
Featured
Garland Texas
1977 cj-5
2006 Toyota Tacoma
The harness is from a Blazer and the ECM while it says is manufactured means nothing it if doesn't have the proper cal.
I can sand and paint a piece of metal. Thus it is manufactured.
might not be bad if you don't want to go through getting the parts yourself. A couple years ago I picked up the whole tbi, wireing harness, sencers, and ecm from a blazer with a 4.3 for $200. That was already pulled. So if you don't mind spending the time looking around, you could do it for half that.
did you pull these yourself or make a list and call around?:cool:
I got it from CL. A guy was parting out the blazer (it had a rod knocking). He pulled it for me.:)
what about for a v8. do you think the gm set up would work with the 360 amc?
    Best for votes
    on specific items
