TCase Howell TBI upgrade, speedo sensor question
Transfer case
Scottyp1134
Santa Rosa
86 CJ7 Laredo, 258, D300, AMC20, D30
Yea, that's a pretty tight bend. That ninety adaptor would semi work but it has draw backs. Needs greasing and causes some drag.
Why not just get a longer cable or put the sensor on the back of the speedometer?
I have a friend with a Howell setup. I'll text him and ask for pics on his placement.
Heard back from my friend with a Howell setup. No trouble with the sensor at the Dana 300 but you have a different Transmission . Your stock speedo cable was already stretched.
I would look into a longer one or try rerouteing your current one.
Heard back from my friend with a Howell setup. No trouble with the sensor at the D300 but you have a different trans. Your stock speedo cable was already stretched.
Thank you for the help looking into this. The length of the cable isn’t the problem. The problem is with the Speedo sensor added in there now the cable is tight against the bottom of the body/floor pan. This is creating a tight bend radius that I am worried about
I have the Howell speedo sensor too, but fortunately I have no clearance issues.
Other than the 90 elbow, I would look into putting that sensor in-line by having another short speedometer cable made up. There are shops that can make it for you, like this one... (Link)-> Speedometer Cables - Speedometer Repair & Calibrations -<
I hadn't thought of the "at the speedometer" solution. That's thinking out of the box!
The howell system (GM TBI) measures speed, but I don't know how accurately or to what detail. I've been playing with an ADX file and ALDLDroid to get live dash data from the system. There is a calculation for speed to get accurate numbers from the computer (and I just use the GPS function anyway.)
In short, I think it just needs to spin relative to your movement and not be amazingly accurate. We all know the jeep speedo isn't the definition of precise already. So do what you need to do to make it work and it will likely be just fine.
You bring up some good points. I may try the behind the speedometer first before I try the short piece previously mentioned. I’m interested in looking at the live data view you are talking about
