Chief #2!
Chief #2!
Niedhogg
Old Time Jeeper
Thor, Iowa
'79 Jeep CJ7 Renegade with 304ci V8, TH400 auto, Quadratrac T-case, Stock 20 and 30 rears with no mods yet, not sure of the gear ratio.. 4" Softride Superlift, w/widetrac shock towers and 35x12.50x15 BFG Mud-Terrains
'76 CJ5, 232 ci, T-150 3-speed, D20 T-case, Corp. 20 rear w/full float axles and lockout hubs and Detroit auto locker, D30 front w/lockout hubs, gear ratio is unknown..
Cool Find!
If you need a few parts, I have a '79 Cherokee here that will be parted out as soon as I get time to do it...
Cool Find!
Cool, thanks! Could use a wiper switch, right off the top of my head, lol! We drove it home last night from Pittsburg, 4 hrs! It ran flawlessly, besides a high idle issue... ordered the carb kit today, along with everything needed for a tune up, plugs, wires, cap & rotor , oil change, new brake rotors & pads for the front (just to be safe).. Needs some vacuum lines replaced on the cruise control, and on the Transfer Case or the 4 wheel switch as my son got stuck in the wet grass and some soft ground this morning before work and 4 wheel would not engage, lol, but should be an easy fix... the front hubs were really hot after the first 5 miles when we stopped to fill it up and I was really concerned the bearings were dry, but he said he had been riding the brakes a bit coming down the hill from the PO's home to the station, so we continued and rechecked after about 50 miles on the highway and they had cooled off considerably, thank god.. Tried to order new bearings for it today as well, but Autozone didn't list any.. any help with this from someone???
Just a note, the Jeep in the picture is not a Cherokee Chief rather a Model 17 Cherokee "S".
Give rockauto.com a try for parts the corner stores dont have.
BJ's offroad.com was a major factor in keeping my J-10 on the road for a lot of years.:D
Yep. The badge on the back is a Cherokee badge, not a Chief badge. It most likely has an "S" in there.
IFSJA is always a good resource.
There really aren't any FSJ specific shops out there with consistently good service. Keeping your vehicle running is not always easy. But it's worth it.
But it's a good find nonetheless and it makes me jealous. I want another SJ Cherokee to compliment my fleet. It will happen one day, I'm sure. I need to finish my other projects first.
So it's a Cherokee S... no chief in the description? The badge on the rear sail panel is an indian or chief's head with an S on the bottom.:confused:
The Chief is an appearance package and nothing more.
The Chief replaces the Cherokee S tape stripping with two tone paint and Chief lettering on the lower body sides and tailgate.
As mentioned you have a Cherokee S
The badge has a Cherokee head in it, not a "chief" head. All Cherokees got one of a couple versions of that badge.
You have a wide track Cherokee S.
The Cherokee S is the base model with the least content. Aside from a lack of luxury options, a wide track S is a solid platform, especially with the 360 rather than the AMC 258 i6 / 4.2l .
If you've got hubs, I'm assuming that either you have the Dana 20 , a Q-Track with the part time kit or someone just swapped hubs in and you're running the Q-Track in e-drive all the time.
In all, it looks like a really good example of the species. You should post more pictures. :chug:
Tough lookin Jeep. I've always wanted a J10. Can you get one of those too and add to your collection?
Haha! You never can tell what I'll come home with, was actually looking on CL last night while we're in Kansas for the holidays... there are a couple prospects...:D
$20.00
  10.0%
