Choke Question?
phinleft
- Baton Rouge, LA
- 78 CJ7, Amc 304 V8 - AMC 20, DANA 30, Quadratra Trac TH400, 35" Mickey Thompsons MTZPainted LSU Yellow/Gold. Modified with 4bl Edelbrock Carb.
Choke plate is closed before starting. I thought after 5-10 min of running it would open fully once warm. The plate only opens 2-3 inches. If I open it more, the engine kills. Any ideas, what is the cause? After running it for 30 minutes the choke plate will open about half, and the engine will die. If I adjust it manually and slightly close it. The engine runs great again.
Would adjusting the air/fuel adjustment make any difference.
Stock carter carb with a coil thermostat, which is ok.
I have changed all the hoses on the carb and egr valve. Would the egr valve cause this problem?
