TCase Gear Oil question!
Transfer case
Arlee
Denver, CO
1984 CJ7 Laredo 4.2L T5 D300 AMC20TL MOPAR MPFI
Refilling my 1984 CJ7 Dana 300 Transfer Case and Dana 30 front diff. Looks like I need a GL4, NOT GL5 gear oil (75w90 or 80w90) to fill both (no Limited Slip additive). (Apparently if it is GL5 rated it has brass corrosive sulfer in it.) I cant seem to find any that isn't also GL5 rated anywhere! Anyone have suggestions on where to find the proper gear oil?
NAPA has Vavoline GL4. I ran a T-4 with Castrol GL5 for almost 1/4 million miles when I had many people saying it would not last. Also the differentials with the Castrol GL5. I run my rebuilt T-176 with GL4 now.
It looks like Valvoline Syncromesh for Manual Transmissions that I used in my T-5 might work as a GL4 gear oil with "roughly 75w-90" weight. Anyone done that in the Dana 300 and front Dana 30 Transmission ? NAPA here doesn't have any GL4.
Amazon
Red Line MT-90 appears to be a synthetic 75w90 GL4 gear oil! Found some on Amazon...think that will work for Dana 300 transfer and the front Dana 30 differential.
Napa is where I get mine
I finally went with Red Line MT-90 75w-90 GL4 gear oil for Dana 300 xfer, and valvoline syncromesh (GL4) for the T-5 .
FYI...the shop I had refresh the T-5 and Dana 300 recommended "a good synthetic 75w-90 gear oil" for the DANA300, and "regular 10W-30 motor oil" for the T-5. I told him I was planning to use Valvoline Syncromesh and he said that would work fine, but probably unnecessary, overboard and expensive. So I errd on the side of overboard for my fresh tranny!
I just rebuilt my T-177 and Dana 300 as the previous owner loaded them both with a GL-5 and the synchro's in the 177 were black and heavily glazed and the main shaft bearings were singing. I could not down shift into 2nd or 1st. Everything is running in MT-90 and very happy.
$20.00
  10.0%
