CJ-5 Wide track?
CJ-5 Wide track?
cdlongjr
Newark, De
1983 Jeep CJ-5, 1987 Wrangler YJ, 1974 J-10
What is this? I saw it in a catalog today.
82 and up CJ's have wider axles (diffs) then prior versions for stability... A 76-81 CJ can use 82 and up 'wide track' axles with little - really no fabrication (the shocks mounts are a little different). Just have to swap them out.
You have a wide track axle CJ.
The wide tracks were standard on 1982 & up CJ7s and CJ8s. The CJ5s used the narrow axles through the 1983 model (last year for CJ5 ). The wide tracks are about 4" wider than the narrow tracks.
hmm seems like a little confusion here....
I was under the assumption that Cj-5s were all narrow trac through the final year ( 83 ). Cj-7s and Cj-8s received the wide trac starting with the "82" model year. Its hard to say all or always with Jeeps since Amc would use just about anything available at any time. :D
