CJ windshield frame
CJ windshield frame
grunt
Connecticut
1979 CJ 304, 400 automatic
Replaced the broken fiberglass windshield frame in my project because it was broken in a accident, Any way the wires for the wiper motor on the fiberglass one, the previous owner drilled a hole at the bottom of the windshield frame to attached to motor. Picked up a complete metal frame and glass complete without wiper motor and I don't see a hole at the bottom of the metal frame for the wires. Am I missing something or just drill a hole at the bottom of the frame? All help will be appreciated.
don't know what year it is they ran wire a few ways through the years my 54 has a little hole with a rubber grommet in the cowl behind the windshield but mine has vacuum motor wipers but you prob could use the same kind of idea for the wires instead of a hose like mine
Hmmmm...So if you lay the windshield down on the hood and ride like that you need extra wire I guess? Appreciate the picture 54cj3b, but I still can't tell exactly...anyone else? or maybe another pic? Don't mean to be a pain in the.....
mine comes out the top of the dash and than to the motor. This sandwichs the wires between the dash and the windshield frame. I don't know if this is stock or from the PO.
on the 70 mine goes through a grommet into the frame
Just above the dash there is a 1/2 X1 inch hole about 6-8 inches from the left side that the wires go through this is on a '77 CJ5 . Hope you can see it.
That's exactly how mine is on my '76
