CJ5 304 Junkyard TBI install
If you are going to run an external pump, I would suggest a high flow fuel filter like a Fram G3802A. Prior to the pump to protect it. Placed at a location below or at the level of the fuel tank. Mine seems to work mounted on the frame next to the transfer case. The fuel pretty much has to be able siphon to the pump. The fuel tank vent system must be working properly also. Watch the gas gauge, running out of gas can overheat and burn up the pump. Good Luck!
Sounds good. I just ordered one. Thank you.
I had a Mr. Gasket clearview filter show up today but it ended up not being suitable for fuel injected systems.
For your compression testing, you might want to look up the correct way to do it. I wasn't sure how to do it until recently. The fuel filter I suggested is the one that Howell recommends and it seems to work for my application. Since it is mounted between the pump and the fuel tank there is no pressure behind it. I do like those clear fuel filters though, as they can show water and other debris in the fuel system.
I want to say that the go to OEM pump and filter came from a 90s Ford van which was frame mounted
Is that the E2000 pump like the f250 trucks used? It's cheap but the pressure is so much higher than I could ever need. Have you used it without problems?
That pump sure looks like the one I have, although you could run the E2000 as the pressure regulator is in the throttle body and does have a little bit of adjustment if need be.
I'm not quite sure, I'm a fan of OEM parts so that I can go to any parts store for what I need, so I heard about that one and made a mental note of it
Yes, came in the 80s-90s f250
Use the gasket on the right to drill your holes in your adapter then install the tb with the one on the left
I picked up a GQ-4x EPROM programmer and a UV light eraser locally. Having trouble finding a ALDL to usb or ALDL bluetooth cable that isn't 10-15 days away. Anyone know of a place that might sell them in Canada? Or does anyone in The Vancouver BC area have one?
I have started stripping the wiring harness apart. I got the 1227747 ecm from a 90 chevy 1500, but all the wiring and sensors form an 89 4.3L s10 Blazer. I should be able adjust injectors to the correct specs by doing the adjustable pressure mod on the regulator. Looks like the sensors are the same between the two engines.
I can't find a wiring diagram that matches the 4.3L wiring harness but that shouldn't matter right?. If I go by the 1990 1227747 truck ecm's wiring diagram, and just switch pins in the plugs to match the 90's diagram's routing, I should be fine right?
Again, thanks for all the help
drool, just wow thats so good looking, the Chinese knockoff mill we have at work is nowhere near as nice as what your CNC is putting out
I'm so spoiled with all the equipment and expertise available to me right now it's ridiculous. Next year I have over 200 hours slotted to metalworking and automotive in my program. I'll be doing a whole build on this Jeep then, can't wait.
see if this is what you are looking for
| Repair Guides | Wiring Diagrams | Wiring Diagrams | AutoZone.com
