CJ5 Front Disc swap; Now calipers way too tight
cglax6
Lifetime Supporter
Featured
VA
'76 CJ5, 351w, Ford T18/D20, D44 (open), D30 (open), 2.5" BDS spring lift, 31x10.5x15 tires
If the drum brakes worked decent, then I'd bet your problem is the master cylinder. Drum brakes require slight constant pressure to keep the wheel cylinders from sucking in too far. This pressure will cause disc calipers to drag. You can remove the residual valve for the front, but your better option is to replace the master cylinder.
The drum/drum proportioning valve is also different from a drum/disc valve. I got much better braking after changing to a proper disc/drum master and prop valve than I did with the drum/drum master with residual valve removed and drum/drum prop valve.
:agree:
The front drum and front disc MC are different PN's.
You will also want to switch out the portioning valve.
Takes more psi for disc, than shoe type brakes.
Kind of what I figured...which is why I went ahead and got the new MC and valve. I'm sure that'll fix the issue. When it comes in and I get it installed, I'll let ya'll know how it turns out.
Thanks again.
Make sure to bench bleed the MC and use only DOT3 fluid.
Good luck,
