Build Thread CJ5 Hardtop budget build. (converted CJ7 hard top)
rr41mag
Full Time Jeeper
- Panama city florida
- 04 dodge truck, 1966 chevy truck, 2012 rav4
And finally a 1981 jeep cj7 258 hardtop
You should be able to roll them half way down maybeIt seems to me that once you cut down 7 doors that you won't be able to roll the windows down. So what! I want to see it done myself
I put a temporary drywall screw in each corner, put the doors on the jeep, and from the inside used wire to pull the tops in snug then wrapped the wires tight to the bottom screws.
Impressive work!
(May I suggest that you encapsulate the plywood completely with 'glass.)
I will be looking forward to your next projects.Hi Kilo19, I used 1/2 inch exterior plywood, B/C grade (which basically means sanded slightly with no voids showing such as found on CDX sheathing grade).your build has caused me to want to build my own top and doors, only because the roll cage is gonna be custom, and i don't think im gonna be able to find a top that i want...with that said, what size plywood did you use, i have access to 1/4 and 1/2 but did you do anything special to water proof, or would the fiberglass do a good enough job, also any idea on how you mount things on fiberglass?
oh,
GREAT BUILD THREAD![]()
There is a marine grade plywood that is treated similar to pressure treated lumber but I was not sure of the adhesion qualities with the resin. Regular wood soaks up some of the resin into the outer layers, more or less becomes one after its cured. Polyester or epoxy are both waterproof after cured but if not painted then a gel coat (slightly different resin make up) should be applied to seal the deal, but a coat of the same resin used throughout the project will give about the same result.
I used a polyester resin on this but there is also epoxy resins which are much stronger (and more $) and either are compatible with the fiberglass cloth and mats. One of my irons in the fire is antique restoration and I have used the polyester and epoxy resins injected into deteriorated/rotted wood to stabilize it, similar to the method used in log home restorations.
Probably the most important aspect of fabricating anything, in my opinion, is drawing the project to scale on paper (ordinary graph paper works fine) before starting as this will give an accurate view of how the item will actually look.
Fiberglass can be drilled, tapped, ground down, inserts mounted into it, pretty much the same as wood. Reinforced backing plates, ect. should be layed up right into it if you know where something is going to be mounted.
Good Luck on the project, I look forward to seeing pictures!
Al
This is undoubtedly the most interesting build I have ever seen. Great work is an understatement.
