CJ5 Windshield install
- Solutions
- 1
- Atlanta, GA
- 1979 CJ5 Renegade 258, t-18 pretty much stock except for a later model aluminum intake manifold and Gronk 2150.
Holy Cow what a PITA
We are on our third piece of glass and are determined not to break this one!
We are installing the glass with new rubber on a crown repop frame which may be part of the problem. When you lay the frame on top of the glass there is a gap in one corner. Too warped to use?
I called a glass install place and after I explained what a CJ5 was (?!) they said it would cost $216 and they would take no responsibility if the glass broke during install. Nice
Another question. Does the thick part of the window gasket go outside or inside? I would think inside but there is no way to pull the lip over from the inside. Here's a pic of the rubber. The rope is in the channel already so you can see it.
I wish we had another CJ to look at but there are none around.
Thanks everyone... Im sure we'll get it eventually.
. Are they all the same? This one is from Crown I believe.
