CJ7 engine swap from 94 cherokee
steph
central wi
Sorry,don't have a cj yet,just starting to look.
I have two other jeeps
Hi
I would like to take a 4.0L from a 94 cherokee and put it in a 79 CJ7 ,is this a good idea??
How much trouble am I looking at here?
The biggest thing is to get the wireing harness from the cherokee.
HI
I have the complete jeep cherokee with the motor in it running.
Will it bolt up to the old cj,are the motor mounts in the same place??
And what about the bell housing,will bolt up to the three speed thats in their.
I know I have a lot of other question,but all in all,is this worth it?
I can buy the jeep for $1300,body looks good with no rust throw the floor,hard top,some other little problems,but I have the motor here for free to put in it.
Do you anyone that did this same thing?
Thank!
Hey man I'm really interested in what you have going on cause I've got a 79 CJ7 and wanting to put a 93 Cherokee 4.0 high output and aw4 Transmission in I've got complete vehicles and wiring diagrams but my prob is the Transfer Case so I would like to know what if anything you have figured out
anything can be done :cool: that is with enough money. if the 79 your looking at already has the AMC 258 i6 / 4.2l I6 then the job will be alot less complicated. i know its a pretty common swap. hopfully somone will chime in that can tell you what flywheel and clutch to use and if the motor mounts are in the same spot
$45.00
  22.5%
