Engine Starter failed to crank
Black Thumb
St. Louis, MO
1978, CJ-7, 258 Cu In, t-18a, D20
When I turn the key sometimes the starter cranks immediately, sometimes it cranks a little, stops, and then cranks again. I was at a funeral yesterday and when when I left I turned the key...nothing. Fortunately I was pointed down a slight grade so got it slow rolling, put it in granny first, and popped it over. When I got home it cranked like nothing was wrong. Do you think my starter is maybe just slowly failing with age, or do you suspect something else.
Three possible issues I see: (1) starter starting to go out; (2) bad electrical connection; (3) bad solenoid. To test #1, next time it won't crank, tap the starter with a small hammer and see if it cranks. To test #2, check all connections (large cable from battery positive to solenoid, then cable from solenoid to starter, smaller wire from ignition switch to solenoid). To test #3, when it won't crank, jump the solenoid with a jumper cable or even pair of pliers or two screwdrivers (don't burn your hand).
I had a similar issue a while back and I found that tapping the side of the starter with a hammer made to crank. New start fixed it.
Before I realized I could get a slow roll my first thought was to find something to bang on the starter with. The solenoid and the distributor are the newest parts in the Jeep. The connections are good.
I think it's just old (48 years old) and I'll just replace it. Would you go OEM, or one of those mini gear reduction starters? Doesn't seem worth it going from $100 AC Delco to a three to six hundred.
Just go with a regular starter.
For a stock engine, the normal starter. I have a higher compression setup and have one of the mini gear reduction starters.
Replace both the starter and solenoid
The solenoid is only a couple months old.
Check the wire going to it from the ignition switch. They can get loose especially if they still have the factory rubber style connectors
The old starter has power, it just doesn’t want to crank over sometimes, or has trouble in one spot, and if it lands on that spot it won’t crank at all. I bought the new one and will install this weekend. If it doesn’t solve it 100% I’ll reassess.
Ground strap, frame to engine?
Ask me why I think that. Also, after so much time, the brushes in the motor could be a bit worn.
The new started has a big red sticker on it that says "DO NOT STRIKE". Lol.
On the bright side, the Jeep will pop start so slow it's mind boggling. It literally just has to be rolling at a slow walk. I can pop start it on the slightest grade that looks flat.
    Best for votes
    on specific items
  5.0%
