Build Thread Cj8 ground up rebuild
Sent from my C771 using Tapatalk 2
Working on it this week got the grill fenders and radiator mounted up now I need to find a fan an some braided brake line "about 26 ft" for running the dual brakes. And start bending. Rickey let me borrow/ buy that bender off you:D
testing out my handmedown harnesses
You are welcome to borrow the bender, but I only have 1.75" die with it. You are welcome to use one of the notchers as well. You should know that it is a manual bender as I have not even broken it out of the box it came in yet so I haven't bothered to run over to Tallahassee to get the conversion kit.
. I need to finish this bumper build for a friend that I'm swapping for a 92' 4.0 with harness so I can get back on the YJ. I already delivered the rocker guards with step tube.
Cage idea starting to bend tonight or tomorrow
Looks like you are trying to make a cage out of straight cut tube..I told you you could use my bender if you will purchase the air over hydraulic unit to put on it..lol
Seriously though,you are welcome to use it.
I'm not sure about the back part of that cage's look, but it may look better once its done.
No I have tims bender. Going to pick up a notcher now
Ran across this cage and thought it looked decent and figured it might give you something else to look at.
I know its not an 8, but has some nice tube action. No homo...Also I'm talking about the top bars in the cage.
Also, after looking at this one I had a similar plan for my commando, thought it might not look bad after all on the 8 with more straight pipe like you mentioned.
Oh, and check out this dash set up..
Thats almost the same dash except it is higher than I was looking
B pillar is starting to take shape
Fishin fool, I have finally moved to Panama city. You may remember me from Texarkana. I live in the Calloway area. Look for my jeep on the road. I love your roll bar idea. I'd really like to see it in person.
Just give me a call in gonna be working on it all day if you want to swing by
what I woke up to this morning
$135.00
  67.5%
