Clifford Valve Cover
DANsCJ7
Chesapeake, Virginia
1976 CJ7, 1986 Drivetrain, T5, D300, original 258
I've had mine on for about 20 years now but I don't recall having any issues with it.
Due to leftover casting material in the head bolt recesses of the valve cover I could not line up the cover bolt holes. I do not know if all of the valve covers have this problem, but mine did. My AMC 258 i6 / 4.2l is a 1976 with california smog, perhaps this contributed to clearance problems. The change to an original style gasket was my own. If I wanted to use the Clifford version I could have removed 1/8 in from one edge and it would have worked. But like the tabs because they indicated the gasket has not shifted during install.
I used to have problems with my valve covers leaking on my K5 Blazer (Chevy habitual leaky valve covers), threw away the gasket and used "Blue Permatex" gasket. never had another drip of oil, had to let the sealer set 24 hours.
