Clutch Clutch fork hitting bellhousing, clutch not disengaging.
AndyD in BC
Nelson, British Columbia
'76 CJ5, 258, T18, D20, AMC20, D30
I’m not a big Transmission guy, but when I did my swap from AMC 150 /T-4 swap to AMC 258 i6 / 4.2l /T177 I was looking at that same adjustable T O bearing. I got one if you want it to try. You can have it if you want. I didn’t use or even try it. I used the one in the box with the Luk kit. I don’t remember it being that cost at all.
I’m not a big transmission guy, but when I did my swap from amc 150/T4 swap to 258/T177 I was looking at that same adjustable T O bearing. I got one if you want it to try. You can have it if you want. I didn’t use or even try it. I used the one in the box with the Luk kit. I don’t remember it being that cost at all.
That would be awesome, It's been tough to find info to figure out what the best fix is. If it doesn't work out, I'll pass it along to someone else. I'll send you a PM.
Wow my mistake on this AndyD in BC. I thought this was KRUPP’s thread. I guess I should have looked a lot better. I knew he was working on his Transmission and I offered it to him to try since he and I have been here on the forum for a while. I will see if he wants to try it. If he does not I will let you know and have it at a lower cost for sure than what Novak wants.
Wow my mistake on this AndyD in BC. I thought this was KRUPP’s thread. I guess I should have looked a lot better. I knew he was working on his transmission and I offered it to him to try since he and I have been here on the forum for a while. I will see if he wants to try it. If he does not I will let you know and have it at a lower cost for sure than what Novak wants.
Totally fair, let me know
I sent you a PM.
I don't need that Throwout Bearing. It was just a suggestion as a fix for Andy D. Thanks for thinking of me though.
$45.00
  22.5%
