Clutch Clutch Linkage
Solution
'76 and up used a different bell crank (OE part # 5360104).
The '72-'75 is shorter (OE part # 5351292).
At a glance without measuring you can also tell the difference between the two because the grease zerk fitting is in a different position relative to the "arm" on the one end as well.
And then the even older '66-'71 is a lot different (OE part # 941232).
Do you have a body lift, by chance?
Can you post a picture of what you mean by “2 inches too short” ?
No body lift. I'm not sure i can get a picture where it's located. The bell crank in the new kit is shorter than the ome.
I’m not 100% sure, but I believe that bell crank was a bit shorter in early generation CJs, like up to ‘75.
Maybe you have one of those?
The original on my ‘86 is 9” +/- long.
Solution
TSB8C, you nailed it, as usual!
Thank you for taking the time to explain this. I don't think I could have received a better explanation anywhere.
$20.00
  10.0%
