clutch mount
clutch mount
scooby
van lear ,ky.
77 cj5 304
help I am starting a build on a 77 CJ5 it has had the frame blasted and painted and all mounting brakets removed and didnt come with it and i can not figure out were to mount the clutch braket not even sure what the mount looks like
CJ5 -CJ7 -CJ8 -Scrambler-Clutch-Linkage-Components-Parts-Diagram.png" data-src="/community/proxy.php?image=http%3A%2F%2Fwww.autopartslib.com%2Fwp-content%2Fuploads%2F2009%2F12%2FJeep-CJ5 -CJ7 -CJ8 -Scrambler-Clutch-Linkage-Components-Parts-Diagram.png&hash=09bb0873bd48dfd5977f158a032e1b2e" data-lb-sidebar-href="" data-lb-caption-extra-html="" data-single-image="1"> Jeep-CJ5-CJ7-CJ8-Scrambler-Clutch-Linkage-Components-Parts-Diagram.png
Part 7 goes from the clutch pedal to the linkage part #1.
Part 1 is held in place with Part 14 (mounted on the inner firewall).
Part 1 is also held in place with Part 5 (mounted to the bellhousing).
As part 1 rotates it pushes on part 2 and 4. That is what pushes the clutch fork (part 3).
I am guessing the main issue is mounting parts 14 and 5 so part 1 can rotate.
I hope this helps.
