Clutch movement question
jakeh937
- Petaluma, CA
- '79 Cj5, 258 with Howell Fuel injection kit, T18 with dana 20 Tcase, dana 30 front with Detroit locker, AMC 20 rear with LSD and one piece shafts, Warn 8k winch, 1" body lift, 2" suspension lift, 33 tires
Just acquired a 79 CJ5 . While driving it I noticed that sometimes the clutch pedal would not have full motion (like when then clutch engaged the movement of the pedal was very little) I can reach down and pull the pedal back and it would be fine again. When I got home I crawled under there and noticed that the clutch fork is loose. (Like I can move it up and down and it sort of pops. If this normal? Should that move up and down? Am I missing return springs or something?
