Clutch movement question
I just replaced the bell crank and all the little bits that go with it and the rod it comes with that you are talking about is straight.
Also I would advise changing out the rod that goes from the pedal inside through the firewall to the other end of the bell crank with this one:
https://www.morris4x4center.com/rug...h-linkage-kit-stock-3-body-lift-16919-30.html
I actually upgraded to that one as well! When I get it back, I’ll send you some pictures of it and how I did mine. [emoji1303]
