Clutch question
Clutch question
Hedgehog
Always Off-Roading Jeeper
Tucson/Marana Arizona
I've got a standard clutch behind my AMC 360. The flywheel is drilled for both a standard clutch AND a bigger clutch. The assumption is the bigger clutch would be a heavy duty model. What are you running with your 360?
Luk gold
great clutch at a good price. LT warranty
The bigger clutch is no doubt made for the heavier loads. You'll want to make sure that it will fit inside the bell housing if you decide that it's the way you want to go. I've heard of times that a bigger clutch/pressure plate didn't fit.
I'm running a torque converter behind my 360...LOL :D :chug: :chug:
