Clutch torque
Clutch torque
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
Is the torque of a torque conveter the same as a clutch plate on a AMC 304 ( the bolts that hold it on the flywheel)? The AMC 304 seems to be vague on specs. I have it at 23 pounds. Can anyone tell me if that is correct. Would a person use red or blue loctite on the bolts. And would lock washers be used on the bolts? Thanks
no lock washers and blue lock tite. torque sounds good, make sure they are even and equal, cross torque.:D
